Order Ford 3000 Parts Online
3000-4000 ENGINE
Gary McKenzie
12-30-2002 06:25:28
What are the differences between the 175cid and 201cid engines? I know the bore and stroke are different, is it possible to convert the 175 to a 201 by using the 201 crank and boring the block? I would have the pump and injectors recalibrated to 4ooo spec's, but what about the cyl. head? It's just a thought at this point, but any help appreciated.
TimK
12-30-2002 06:53:59
 Re: 3000-4000 ENGINE in reply to Gary McKenzie, 12-30-2002 06:25:28
There have been several posts in the last few years on this Board regarding unsuccessful boring on diesels which don't have sleeves. I think the main problem was cavitation, which in turn results in thin cylinder walls after boring. It also depends on how much you are boring out. Anyhow, I would seriously consider whether to bore one of these diesels or not. Maybe someone else has done what you are suggesting with no problems ?
big diesel
12-30-2002 18:58:41
 Re: Re: 3000-4000 ENGINE in reply to TimK, 12-30-2002 06:53:59
i have about 15 used 201 diesels, if you want to trade your 175, e-mail me
Gary McKenzie
12-30-2002 07:01:02
If I were to bore it, I would install dry sleeves in it, what I want to know is if the 175 and 201 use the same block with the 201 having a larger bore or are they two different castings?
