Order Ford 3000 Parts Online
3000 Ford diesel
Banister
12-31-2002 14:06:19
I was using my Ford 3000 diesel with loader, it was running great, used it for a couple of hours, tractor started sounded funny with a lack of power.
DEAN
01-01-2003 19:07:19
 Re: 3000 Ford diesel in reply to Banister, 12-31-2002 14:06:19
I HAVE A 2000 DIESAL AND IT HAD THE SAME PROBLEM. IT WAS THE FUEL PUMP THAT FEEDS THE INJECTOR PUMP. IT HAD FILLED UP WITH DEBRIS OVER THE YEARS OF USE. MY PRIMARY FUEL FILTER WAS BETWEEN THE FUEL PUMP AND INJECTOR PUMP.I PUT A NEW PUMP ON AND ITS RUNNING PERFECT NOW. YOU ALSO COULD HAVE WATER IN YOUR FUEL.I WOULD CHANGE THE FUEL FILTER AND BLEED THE SYSTEM AND GIVE IT ANOTHER TRY!! HOPE THIS HELP!DEAN
