Transmission won't came out of 2nd gear
Allen
12-31-2002 22:31:33
I have a 1948 8n it was working just fine I was shifting from 1st gear to 2nd gear and the trans just locked up I pulled the shift cover off and all the gears all look fine boy if anyone out there can help ? thanks & HAVE GOOD NEW YEAR
9n141
01-01-2003 09:52:35
 Re: transmission won't came out of 2nd gear in reply to Allen, 12-31-2002 22:31:33
FIX IT NOW. We just fixed one that I bought @ auction (bad trans was written on the hood). There were 5 gears with missing teeth,dealer price gears $1000, I had extra trans & extra set of gears, but we still had to rebuild complete trans. I talked to mechanic friend he said your problem likely showed up first & previous owner contiued to use it until everything locked up breaking teeth off 2 gears, with broken teeth catching in other gears and causing more damage. Hope this helps. P.S. trans repairs are not much if you catch it now. BURT.
