Order Ford 3000 Parts Online
3000 selectamatic trany
john
01-08-2003 10:01:08
needhehp with FORD 3000 SELECTAMATIC HOW BIG OF A JOB TO CONVERT TO STANDER TRANY AND KNOW OF PARTS AVALABLE .JOHN
Larry NCKS
01-08-2003 19:31:50
 Re: 3000 selectamatic trany in reply to john, 01-08-2003 10:01:08
So! What's a SELECTAMATIC TRANNY? I have some parts or will sell a 3000 Select-0-Speed rebuilt. What's wrong with yours? email if interested. I'd not convert if S.O.S can be fixed or swapped for S.O.S.
Fighting suburbia in NC
01-08-2003 11:29:43
Check the archives on this site for more information, pros and cons, and costs than you will probably want to read through. Search under "SOS" or "Selecto-O-Speed". Look for posts by LarryNCKS, Bern, and few other regulars you will see on alot of the SOS posts for really good background information.
If it is not too broke the best thing to do is fix it. A changeover is going to run about a grand for parts and then the real work starts.
BTW, I own a 63 2000 with an SOS and wouldn't swap it for a manual anything.
kydavid
01-08-2003 16:53:01
 Re: Re: 3000 selectamatic trany in reply to Fighting suburbia in NC, 01-08-2003 11:29:43
Change will probably run a lot more than that.Started one last fall for a customer, she later backed out and sold the tractor for salvage (I still have most of it). Found that the rear axle needed to be changed, too. PTO works different (or at least on the unit I have). Also have to change the flywheel. Used was going to run $1500 for 8 speed and another $1000.00 on rear end. Or for another $500 could get a like new one off a 3600. Email me if you are interested in one.
