Order Ford 600 Parts Online
3600 Water Pump
Ken
01-09-2003 19:03:18
The water pump on my 3600 is leaking. What are some sources for a new pump in addition to the New Holland dealer?
I would like to do this job myself. What all has to come off to do the job? I will have a pretty good mechanic helping.
Is there a good service manual that covers this operation?
Ken
01-10-2003 11:11:54
 Re: 3600 Water Pump in reply to Ken, 01-09-2003 19:03:18
I will pull all off the front and clean and replace the hoses etc.
Thanks for the information.
Ken
Roy B
01-10-2003 08:23:19
Ken Not too bad of a job. I think removing the radiator is the way to go. Good time for a new coolant, belt and hoses. My NH dealer only had the new unit from NH, no core, $110 cdn. Good luck . Roy
Van(WA)
01-10-2003 07:46:00
Ken, I took off the whole front end off, as I wanted to clean up all the dirt and ect....but you don't have to, but it makes it easier. You don't need a service manual, easy job to do. Any good parts house could get you a new one, or a re-built....
RickB.
01-10-2003 07:13:28
You can change the pump without removing the cowl and radiator. In most instances, it is much easier and better to remove them, though.
ron
01-09-2003 19:57:42
My FO-41 manuel says to remove the radiator to replace the water pump. It may be possible to get it off without that much work but I know changing the belt was hard enough.Good luck
