Order Ford 3000 Parts Online
Ford 3000 Front End
Berk
02-20-2001 11:15:38
When driving my 3000 on uneven ground there are times when one of the front wheels comes off the ground. The front end seems to be made such that there is no supension, that is, it is two pieces of metal bolted together. I don't know if it is suppost to be like that or not. I'd appreciate any and all help.
Thanks,
Berk
Lee YOUR AXEL!
02-20-2001 13:44:34
 Re: Ford 3000 Front End in reply to Berk , 02-20-2001 11:15:38
third party image
Sounds like your FRONT axel pivot pin is FROZEN!!
Jack up the front end so that BOTH wheels are off the ground. You should be able to move the axel/wheels UP and DOWN with no effort....check for any side ways slop!
Look at the front of your tractor BELOW the front radiator/grill ...you will see a CENTER hole ..that's your CENTER pivot pin.
I have attached an IMAGE that will be close to what yours looks like!
Keep in touch!!
Lee
