4110 injection pump timeing
Horseman
01-10-2003 11:46:09
Any one now were the timeing marks are for removal and installation of a cav pump, 3cyl diesel. Thanks WRP
Rodger
01-12-2003 06:55:57
 Re: 4110 injection pump timeing in reply to Horseman, 01-10-2003 11:46:09
The timing marks for the pump are on the casing which the pump is bolted to. There is a scribe line on the pump casting which is used for alignment with the scribed degree marks on the casing which the pump is bolted. Normal timing is set to zero for the 3 cyl diesel with the cav pump. The timing marks on the casing can be hard to see so you may have to do a little cleaning in the area to find and read them.
Texadian
01-14-2003 08:15:51
 Re: Re: 4110 injection pump timeing in reply to Rodger, 01-12-2003 06:55:57
Horseman, Rodger is correct, you might look at my reply to 4500 timing above for additional info, very similar engine.
