Ford 821 with loader
Allan Wirth
01-14-2003 14:38:06
I was luck enough to receive as a Christmas gift from my wife a 1958 Ford 821-D (Ser. No. 33272). I is in very good shape, I drove it home with no problems. My question is: the shaft that couples the engine to the hydraulic pump for the loader has a lot of longitudinal play and can come out of the spline? at the crankshaft end. The pump is mounted as close to the engine as possible on its bracket. Is the problem that the shaft is worn? Should I just move the pump closer? Any advice appreciated.
Allan Wirth
01-15-2003 05:11:54
 Re: Ford 821 with loader in reply to Allan Wirth, 01-14-2003 14:38:06
Thanks to all for the advice. It was a great gift, but after all the horses, trailers, carriages, hay, etc. that I've bought her, she thought I was due! I'm going to pull the pump off and see what I see.
what kind of loader number?
01-15-2003 05:57:31
 Re: Re: Ford 821 with loader in reply to Allan Wirth, 01-15-2003 05:11:54
what is the serial number tag number for Model?
located on Left vertical main frame by driver step through.
Allan Wirth
01-15-2003 06:15:27
 Re: Re: Re: Ford 821 with loader in reply to what kind of loader number?, 01-15-2003 05:57:31
I can't read the plate - its painted over! I'm going to clean it tonight (I hope - its supposed to be below zero) and then post the answer.
I posted a photo in the gallery
ok good work.
01-15-2003 06:24:14
 Re: Re: Re: Re: Ford 821 with loader in reply to Allan Wirth, 01-15-2003 06:15:27
looks like a 702 or 703. good loader. do you know how many gallons of hydraulic fluid goes into it?
good work. model number should be on the tags upper left corner or near it.
lee johnson
01-14-2003 16:36:31
allen, i have a ford800 with factory loader. the splines on my pump shaft evetually wore out.longitudinal play? i don't know, however it's an easy fix. and it's not expensive. i'd start there. now answer my question: what kind of oil goes in the case that houses the 3point hitch? lee johnson
valvovine 813
01-14-2003 22:30:25
 Re: Re: Ford 821 with loader in reply to lee johnson, 01-14-2003 16:36:31
VV 813. Or ford 134 hydraulic fluid
longitudunal means in and out and it disconnects and pulls out?
01-14-2003 16:28:36
dont seem right. it should stay tight and and the splines lock in to avoid any movement or slippage and rounding over then your out of business. dont see a problem moving it in closer as long as the moving parts arent rubbing on the loader frame or bottom grille unit. try it see if it works but a loose shaft aint no good and she needs to be tight.
Scottey841
01-14-2003 16:28:13
Don't know about the pump problem but..... ..WHAT A WIFE!
I did get a new tractor seat. LOL
I agree
01-15-2003 03:41:31
 Re: Re: Ford 821 with loader in reply to Scottey841, 01-14-2003 16:28:13
I wish Santa brought me a wife with a Ford 821 too. SOme people get more than they ask for don't they!
