Order Ford 3000 Parts Online
3000 pto ball detent
kee
01-16-2003 07:45:36
how come my live pto kicks out while bush hogging. could it be my detent?
Gary McKenzie
01-16-2003 08:00:00
 Re: 3000 pto ball detent in reply to kee, 01-16-2003 07:45:36
It could be the detent, shift fork, or the coupler, on my 3000 it was a combination of all three.
bill
01-18-2003 07:52:59
 Re: Re: 3000 pto ball detent in reply to Gary McKenzie, 01-16-2003 08:00:00
grab the pto shaft and see if it moves more that the width of a nickel..if it does, you need to check the pto bearing and bearing retainer in the rear pto housing. if the little bearing retainer clip is gone or the groove is worn, it will let the shaft move forwards, which means it will disengage the coupler... mostly seen while turning, and then going straight again. if the end of the pto shaft or the shifting coupler ever get a "twist" in them, they will always be trying to unscrew.. or disengage.. and of couse the ball detent and spring should be check and replaced if worn.. the little spring usually is weak after 40 years of being compressed..
