Order Ford 2000 Parts Online
2000 vineyard rops
steve
01-17-2003 02:41:03
just purchased a ford 2000 68 vinyard model, without any roll over protection. it has a very narrow rear axle. 940mm wide between wheel mounts.
with the guards mounted of the seat base. leaving no way to mount normal roll bars. also it does not run stabaliser chains on the lift arms but has brackets on the axles for the arms to slide against, any help on the rops or more stability on the linkages would be appreciated. we seem to have a lot of early fordsons and fords in australia.
Dave
01-17-2003 15:39:42
 Re: 2000 vineyard rops in reply to steve, 01-17-2003 02:41:03
I don't know how yours is set up, but on mine I bolted a 1" plate in between the fender and axle and welded a 3-1/2" square tube with a 3/16" wall and about 4" long onto the plate and a 3" tube will slip down into it and allows me to unbolt the "cage" and remove it when I want. The primary purpose of mine is to protect me from falling tree limbs and small trees. I have some pictures somewhere I will try to find. DR
steve
01-18-2003 02:28:27
 Re: Re: 2000 vineyard rops in reply to Dave, 01-17-2003 15:39:42
thanks for your reply dave. thought about mounting rops forward of the loader mounts.will be kooking out for the photos,
