3 point hitch hydraulic pump
LEE JOHNSON
01-28-2003 18:25:06
i don't have a manual for a ford800, and i do not want to wait 3+weeks for something thats gonna cost me 60bucks+shipping, for that money i expect it sooner.SO, where on the net can i find illustrated information about bleeding the dirt and water out of the 3 point hitch hydraulic pump???? guidance greatfully agnowledged. thankyou.
ZANE
01-29-2003 06:03:41
 Re: 3 point hitch hydraulic pump in reply to LEE JOHNSON, 01-28-2003 18:25:06
If you have dirt and water in the hydraulic pump bleeding it ain't gonna fix it.
You need to first clean out the lift reservoir and change the oil. Try taking out the lift drain plug and pouring about two or three gallons of diesel fuel or kerosene though it to chase out some of the contaminants.
Refill the lift with 134 equivelant oil and then remove the pipe plug from the front of the hydraulic pump. Place a container under the hydraulic pump to catch the oil you bleed out. Start the engine at idle speed and let it run until all the air bubbles are gone from the oil that is escaping the pump bleed hole
Ain't there
01-29-2003 05:05:34
Lee I don't want to sound rash but where would you keep what your asking for on the internet for others to use free so that you could expose yourself to law suits for copy right infringment? Got my fully illistrated reprinted ford shop manual on e-bay for 25 bucks and it came in three days.
