3pt hitch question
Allan(MA)
01-31-2003 05:54:22
I have an 821 with PTO but no 3pt. It also has a loader. Has anyone ever heard of a 3pt add on with the lift arms driven from an external pump? Kind of the opposite of driving external hydraulics from the 3pt pump.
Tony Jacobs
02-01-2003 15:17:51
 Re: 3pt hitch question in reply to Allan(MA), 01-31-2003 05:54:22
Hi Allan, Why just locate a Ford tractor for parts with the three point hitch on it and install it on your tractor. It will be simpler and probably cheaper to do it the way they were built than some mickey mouse setup that would not work as well. Thanks Tony Jacobs
Allan
02-02-2003 04:04:53
 Re: Re: 3pt hitch question in reply to Tony Jacobs , 02-01-2003 15:17:51
You're right, of course. I just was curious. By the way, I discovered that my tractor has a Sherman transmission. I saw a photo of a Sherman shift lever and said "I've got one of those". I thought it was some kind of disconnect since I only moved it back and forth between N and STD.
