Order Ford 3400 Parts Online
3400 hydraulics
steve oliver
02-06-2003 11:18:15
I have a 1972 ford 3400 industrial tractor. Tractor has to run a few minutes before lift arms
will raise. Works perfect otherwise. It has the correct fluid/level and I have changed the pickup
filter.Thanks in advance for any suggestions.
RickB.
02-06-2003 15:29:15
 Re: 3400 hydraulics in reply to steve oliver, 02-06-2003 11:18:15
Rebuild the pump. pay particular attention to the suction tube seal at the back of the pump. When the pump is off blow low pressure compressed air down through the suction tube to backflush the suction strainer, then drain & refill the oil. Remove the fill cap during this proceedure,
