Order Ford 2000 Parts Online
1963 Ford 2000 gas 4cyl -cam gear for hyd pump trashed
Scott HouTex
02-23-2001 12:48:09
The cam gear that drives the hydraulic pump has
failed- half the teeth missing, gear is wobbly loose. I have not started to disassemble yet.
What can I expect? Is it likely that the camshaft
is also damaged or is there a pin or key that
holds the gear to the camshaft that may have failed? The pump looks good with no apparent damage to
its teeth.
Marc
02-23-2001 14:01:53
 Re: 1963 Ford 2000 gas 4cyl -cam gear for hyd pump trashed in reply to Scott HouTex, 02-23-2001 12:48:09
The gear is held on by 6(?) bolts that screw into the end of the cam.
