134 ford motor
Eddie
02-14-2003 15:29:42
I have a 134 Ford motor in a brush chipper. Best guess is from the early 50's. The only problem I have is it leaks oil from the crankcase breather vent. My mechanic said I had "excellent" compression, so I am not suspecting much blowby.I was told air comes into the crankcase from the lower vent and exits out the vent on the valve cover. Both vents have a wire mesh filter that is dirty. I soaked them in gas for 3 days and blew them clean with an airhose but they are still pretty dirty. Could this be my problem and if it is are these filters available? Any suggestions? Thanks, Eddie
Scott
02-14-2003 17:30:42
 Re: 134 ford motor in reply to Eddie, 02-14-2003 15:29:42
If you mean the oil comes out the top breather maybe the rocker arm oiling tube is out of place. Your local New Holland (was Ford) dealer has the breather elements and upper breather cover gasket, check your yellow pages under tractor dealers, farm equipment or lawn mowers for a dealer if you are not sure where one is near you.
Eddie
02-18-2003 06:02:28
 Re: Re: 134 ford motor in reply to Scott, 02-14-2003 17:30:42
No, sorry I wasn't clear. The oil is coming out of the lower breather vent on the side of the motor.
