1995-6 345D??
JAE-Tx
02-19-2003 06:01:35
Looking at an "almost new" 345D industrial loader - anyone ever work one? Any opinions?
I've only ever worked with older Ford ag tractors, but I need one to clear a little land.
Thanks for any input.
Texadian
02-19-2003 15:21:39
 Re: 1995-6 345D?? in reply to JAE-Tx, 02-19-2003 06:01:35
345D was built from 92 to mid 98 with a 201 inch 3 cylinder non-turbo engine, from mid 98 to 2000 with a 192, turbocharged lower emissions engine. It has a 3000 pound lift capacity loader and 8 X 8 torque converter reversing transmission, a few were built with an 8 speed manual shift transmission. This is a very similar tractor to the 4500 version of the 4000 series ag tractor that started in 1965. It a very reliable tractor that has been refined gradually over the years and it should have good value depending on condition. Watch for block porosity; it has no sleeves, cylinder walls will perforate at 3000 to 5000 hours if it has not had diesel antifreeze and has been used heavily. Torque converter transmission has a slick lockout when using with implements. Watch for any sign of slippage in the forward and reverse clutches.
