1100 Ford Diesel
need quick advice.
Bama Binder
02-20-2003 22:04:42
I found an 1100 Ford for sale. Seller says it has 460 hours or so on it. Tractor looks very clean. I am thinking about replacing my 184 Intrnational Cub which needs some more work with this one. My cub has a 5 foot finish mower and I really don't want to go smaller. The Ford has no mower.
Is the Ford a good replacement for the 184 for mowing lawn and using small implements on 2 acres? The Ford appears to be in better condition than my 184.
Will the 1100 pull a rear mount finish mower or should I just run a 4 foot and go faster? I have a JB LX 178 for close work.
I was thinking about going to a 640-661, but can't find one for less than $3200. And weight becomes an issue as my land has a tendancy to stay wet and I need a light machine with good flotation.
Can anybody give advice or their experiences?
bill mazzarello
02-03-2005 10:41:14
 Re: 1100 Ford Diesel - need quick advice. in reply to Bama Binder, 02-20-2003 22:04:42
i have been running a 5 foot rear mount finishing mower on my 1100 for years and it works fine no problems at all
Eddie Pettrey
02-21-2004 06:35:43
I just purchased a 1100 desiel and would like to know what year it was built. It has 400 hours on it. I would like any other info on it I can get.
nhpartsguy
02-23-2003 23:16:00
Years ago while working summer jobs in high school I spent lots of time on an 1100. We used to, believe it or not, run a 5 ft rotary mower behind it and not just in short stubble grass. It was used to mow down unused lots with 2-3 ft. heavy grass. I had to go slow most of the time but it worked great. You'll need front end weight regardless if it's 4WD or not though - it WILL pull wheelies. It's a nice little tractor made by Shibauru of Nihon(Japan). Parts will be cheaper for the 100 series tractors though.
RWK in WI
02-21-2003 06:53:28
Ford literature shows the 1100 to have aout 11.5 PTO HP and about 1400# for weight. They show recomended mowers to be 48" mid-mount, 48" rear mount, rotary cutter ( brush hog ) 48", Fail mower not recomended.
I hope this helps you.
Dick Kraus
WayneB
02-22-2003 20:04:32
 Re: Re: 1100 Ford Diesel - need quick advice. in reply to RWK in WI, 02-21-2003 06:53:28
I have a 48" belly mower for my 1100 that has live belt driven electric clutch PTO and all the attachment hardware. Contact me if you are interested in it.
