3pt hyd system
don N.C
02-21-2003 13:42:12
I JUST CHANGED THE HYD OIL IN MY 1964 FORD 4000 AND NOW WHEN I RAISE MY BLADE I GET A VIBRATION I USED (COASTAL 303 FLUID) FROM NAPA IT IS WHAT THEY RECOMMENDED WILL THIS PROBLEM GO AWAY AS THE FLUID GETS HOT OR SHOULD I CHANGE IT TO SOMETHING ELSE ALSO THE TRACTOR STAYS IN THE SHOP WHERE THE TEMP IS AROUND 60 DEGREES THANKS FOR ANY HELP OR SUG, DON
Surfin Cowboy
02-23-2003 08:18:27
 Re: 3pt hyd system in reply to don N.C, 02-21-2003 13:42:12
Probably needs to pump up solid, may be air in pump, and will probably go away as you use it?
