Order Ford 2000 Parts Online
1975 2000 brake pedal
JM
02-23-2003 10:10:17
The right brake pedal will not return. The brake is not acting as it is dragging , but I am afraid that the shoes mut be touching the drum. Are the springs or return mechanism internal to the wheel assy. and/or brake drum?
Any help would be appreciated. I have an owners manual, but it is not much help for this problem.
Thanks in advance.
JM
Hugh
02-23-2003 16:17:32
 Re: 1975 2000 brake pedal in reply to JM, 02-23-2003 10:10:17
I know this is going to sound pretty stupid but here goes anyway. There should be a return spring for each pedal under the floor board. If one is missing or broken that pedal will not return. I had the same problem.
JM
02-28-2003 13:56:31
 Re: Re: 1975 2000 brake pedal in reply to Hugh, 02-23-2003 16:17:32
Hugh,
Thanks for the help. You gave me the answer. I am embarrassed at something so simple, but I am more thankful than embarrassed!
JM
