Order Ford NAA Parts Online
Ford NAA won't idle.
Brad
03-03-2003 17:06:04
My 53 Jubilee starts up okay runs for about 15 seconds then quits. The tractor has had a recent tune-up and rebuilt carb, initially ran fine. Gas is fresh.
Thanks for any input
Dan MI
03-05-2003 18:37:39
 Re: Ford NAA won't idle. in reply to Brad, 03-03-2003 17:06:04
I have a 54 NAA I had a similar problem with mine. It turned out to be the fitting that threads into the gas tank that your sediment bulb connects to. It had become plugged with years of grud from the tank I had to drain all the gas and remove the the valve/fitting assembly and clean with compressed air and fine wire pick and it fixed the stalling problem. And this was after I had rebulit the carb etc etc good luck Dan
Brad
03-09-2003 11:40:38
 Re: Re: Ford NAA won't idle. in reply to Dan MI, 03-05-2003 18:37:39
Thaks Dan, I was thinking this was a fuel related issue. I disconnected the fuel line to the carb to check for restrictions, there was a slow trickle of fuel flowing through the line. I am not sure how steady the flow should be but your idea sounds like a good starting point. This tractor originally belonged to my wifes grandfather and then her father, she tells me that this tractor always ran so I need to solve this issue.
Thanks again.
