Order Ford 640 Parts Online
Ford 640
Brad
03-05-2003 18:10:06
Today I looked at a Ford 640 with loader. It has been converted to 12 volt and appears to be in marginal condition. I drove it and the only noticeable problem was the brake was working properly. The clutch brake worked fine however. This tractor is farm from being in great shape but there were no apparent leaks in hydraulic lines etc. PTO and 3 pt all seemd to work ok. Rear tire rubber will have to be replaced eventually. Asking price is $3750. Is this a reasonable price? I don't know a lot about tractors and don't want to get taken. However, I need a reliable tractor about this size for work around my 13 acres. Moving sand, bush hogging, discing, etc.
John in MI
03-09-2003 05:12:22
 Re: Ford 640 in reply to Brad, 03-05-2003 18:10:06
Hi, I have a 650 (5 speed trans)essentially the same machine and I gave 3000 for it last year(and would do it again every time I see one if I needed it). The 640 is a great little tractor. For cost, parts availability, and being easy to fix yourself, they are terrific. I don't have the bucket on it but I do have one on an 8N. For practical purposes the bucket will affect either tractor the same way since neither are heavy or have power steering. The big question is whether it is enough tractor for your 13 acres and how hard you're going to work it. For light loading on occasion it'll do the job. So if you've got more time to move that pile of sand you're OK. With the loader on you'll lose some turning and maneuverability in the dirt and snow, it's a bit hard on the front end components and it'll affect some of your dirt work when using the 3 point. That said, it sure is nice to have the bucket on there when you need it. The extra cost for the loader is reasonable. Make sure you have the compression of the engine cylinders checked before you buy. Most things you could do out of pocket but you don't want an engine overhaul to happen fast. Make sure the hydraulic movements and they work well. Hope any of this has helped. jc
Jim.UT
03-08-2003 06:07:38
I think you were trying to say the brakes do NOT work properly. With a loader and no p/s you'll want working brakes! There will be times that the brakes will be the only way you'll be able to steer the thing.
Bad brakes could be a sign of leaking axle seals. It's a do-able job, but it is a lot of work. I did the right side of my 850 last spring. Cost me about $100 in parts because I messed up the first time and had to buy parts twice. The learning curve can be costly....
Craig in Michigan
03-06-2003 13:02:59
My 640 is in really good shape and I only paid 3,000 in 2001. I don't have the loader, but I don't think that would make a lot of difference (could be wrong).
tlak
03-06-2003 04:12:36
If it doesnt have power steering and if the loader is the narrow trip bucket I would keep looking. Pair of rears loaded, for counterbalance of the bucket, $500+ and then if the rims are shot.
