Drag links
Bob
03-14-2003 13:13:41
i'm trying to change the tie rod ends on the steering sleeve, after 40+ years of rust and paint is there something i can do. help appreciated.
John W
03-15-2003 13:58:35
 Re: drag links in reply to Bob, 03-14-2003 13:13:41
Bob, I had the same problem and with heat, PB Blaster a few days soaking and a monkey wrench I was able to get them off, not fun and it took all day even after the soaking.
I held the rod end in a large vice and turned the sleeve with the wrench. Remember one end of these are left threads, not sure which but any movement would be good.
I did drill a hole in the middle of the sleeve and used a rod to help twist it off. This helps in adjusting the toe in also. Hope this helps
John W
