Order Ford 3000 Parts Online
3000 lift prob
Rick
03-18-2003 09:30:26
Tried to plant some fence posts this weekend, and the lift would buck like crazy--no fine control. Any suggestions--how tough to fix?
nelson
03-18-2003 18:38:11
 Re: 3000 lift prob in reply to Rick, 03-18-2003 09:30:26
Rick, are you sure you are in position control mode. Small lever in front of main lift control lever ,pull up on lever to vertical position.
Main lift handle should start to move arms at about half way on quadrant. If not tower has to be lifted off and inside linkage reset or checked for wear. I have done many. good luck.....
