Order Ford 2000 Parts Online
2000 Ford Oil Pessure
Jay
03-20-2003 17:24:35
I did not purchase a older 2000 Ford (62-63?) gas 4 cyl today because the oil pressure was 33-34 lbs running cold. My friend says thats ok. Is he correct. Is $3500 a little much for it if the metal is only fair with rust spots and a very bad case of peeling on both colors and the breaks are shot. It seems to run ok. Thanks Jay
ErnieD
03-20-2003 17:51:02
 Re: 2000 Ford Oil Pessure in reply to Jay, 03-20-2003 17:24:35
If the gauge was accurate and the oil the correct weight and not thinned out, it would be lower than I would care to see it. If it nose dived after warming up, suspect poor bearings. Maybe the oil filter was last changed during the Carter administration. I don't know the lube system that well to understand how the filter bypass would affect the system pressure.
Brakes are not that expensive, just a pain to access. A good paint job is not as important as good bearings. Sounds like the whole machine was not taken care of.
