Order Ford 4000 Parts Online
Ford 4000 hidraulic lift system
Alberto Braghet
02-28-2001 01:15:43
I have a Ford 4000 3 cyl diesel with 8 speed trans. and hydraulic PTO.
I do not know the correct use of the flow control knob and of the selector lever (I have no user manual). Can anybody help me or send the copy of the user manual obout the lift sistem? . Thank you.
frank
02-28-2001 16:52:32
 Re: ford 4000 hidraulic lift system in reply to Alberto Braghetta, 02-28-2001 01:15:43
Hi !! I have the same type tractor.
When the selector lever is in the up position it brings the 3 points to the preset height .
The preset height is the one set by the control lever (the lever that brings the 3 points up and down).
Let say you set the 3 point a a certain height , all you have to do to bring it down without loosing that preset height is to bring the selector lever in the down position and the 3 point will go all the way down...and when you bring the control lever up the 3 point wil go back to its preset height automatically.
Hope it helps.
By the way ...what year is your tractor
My e -mail is fsalois@yahoo.ca Frank,
Alberto Braghetta
02-28-2001 21:39:54
 Re: Re: ford 4000 hidraulic lift system in reply to frank, 02-28-2001 16:52:32
Thank you Frank!
Can you tell me something about the flow control knob?
Alberto
Frank
03-01-2001 10:14:50
 Re: Re: Re: ford 4000 hidraulic lift system in reply to Alberto Braghetta, 02-28-2001 21:39:54
The control knob regulates the rate at which the 3 point will respond.
