172 seal problems
eric
03-28-2003 18:48:31
I am having trouble with the real seals in my engine, not the rear crankshaft seal but the wedge seals on each side of the rear main cap. The one seal fits tight but the other seal is loose. I even soaked the seals in oil for 2 days. I even switched the seals back and forth but the one side of the cap is still loose, bolts are torqed to spec. Any help would be appreciated.
Gary-Miss
03-30-2003 07:13:37
 Re: 172 seal problems in reply to eric, 03-28-2003 18:48:31
MOST of these rear main side seals have been replaced with the seals that slide in easily, then, you drive a nail looking thing in (read the directions) at the side and this tightens the seals up. Much easier to install than the old type.
