Order Ford 2000 Parts Online
2000-similar oil leak as below
Drew
03-29-2003 15:22:33
I have a 73 2000 series and was convinced my oil leak was coming from the pump mounting gasket. Local dealer charge me 5$ for 1 gasket-wish I knew more people like Tom. All back together today- leak is coming from front of pump- out of pressed in bushing arrangement. It looks liker there is a small roll pin holding this together. Can anyone shed lite on how this is sealed, and if repair is possible without removing pump? Thanks for your time...
RickB.
03-30-2003 03:12:20
 Re: 2000-similar oil leak as below in reply to Drew, 03-29-2003 15:22:33
The roll pin retains the shaft that carries the intermediate pump drive gear. There is an o-ring on the shaft that prevents the leak that you have. The o-ring is old, hard, flatsided, and or cracked. The pump must be removed to pull the shaft. Don't misplace the thrust washers. The shaft is drilled and tapped 1/4"-28 so you can thread a bolt in the end to pull the shaft after removing the rollpin.
Drew
03-30-2003 09:38:14
 Re: Re: 2000-similar oil leak as below in reply to RickB., 03-30-2003 03:12:20
Thank you for the reply. I kinda figured as much- the real battle is with the oil line- someone rounded it off, and it is really in there. Just for ha-ha's, I gooped up the shaft in the front, and now the leak is coming out of the roll pin!!! Just my luck-
