3 point lift capacity
Mark McElvy
03-29-2003 20:12:28
I would like determine the lifting capacity of the 3point on a 1964 4000 Diesel.
bill
03-30-2003 06:20:44
 Re: 3 point lift capacity in reply to Mark McElvy, 03-29-2003 20:12:28
remember that due to leverage, the farther out the weight is, the less it can lift.. but its about 1000 to 1500 lbs at the end of the lift arms.. ideally it will be when the relief valve starts to leak down due to load..if everything else is in good shape.. sorry i dont have the exact spec..
newer tractors are now measure at 24 inches behind the lift arms.. iirc.... and can be from 1700 to 3500...
good luck .. bill
bill
03-30-2003 06:19:30
good luck .. bill
