Order Ford 4000 Parts Online
730 loader for a 4000SU
Bill Oakes NY
03-31-2003 17:34:17
I want to use a front loader on my 4000SU. Will a Ford 730 from a 801 fit on my tractor? If not, can anyone tell me what I need to look for, in a used loader? Thanks for helping.
bill
04-01-2003 11:38:44
 Re: 730 loader for a 4000SU in reply to Bill Oakes NY, 03-31-2003 17:34:17
yes,, but you might need a dif bracket at front mount. the 730 was actually one of the correct loaders for this tractor. two additional holes were drilled in the front bolster or front casting that holds the axle.. in addition to two existing holes used to bolt the front bracket on. the rear bolted to the existing rear axle.. sometimes using both bolts, sometimes using just the front bolt depending on the 2000/3000/4000 being installed on.
