Order Ford 3000 Parts Online
3000 hourmeter
Jim
03-01-2001 09:14:55
My proofmeter hasn't worked on my 3000 since I bought it. I'm wondering if there are any common problems or if anyone can give me a suggestion as to where to look first.
Thanks,
Jim
RonB
03-01-2001 18:00:58
 Re: 3000 hourmeter in reply to Jim, 03-01-2001 09:14:55
I only had to replace the fiber gear that runs off of the generator to get my tach and meter running correctly on my 2000. $10. gear from Walt's tractor parts. I took the gear assembly away from the generator and spun the cable shaft going to the tach by hand. The tach moved indicating the tach and cable were okay. I inspected the old fiber gear but it looked pretty good (even when I later compared it to the new one). I took a $10. chance and bought the new gear drive and it did the trick. Hope this helps. RonB
Van
03-01-2001 11:58:06
I would check the "cable" first! If it seems to be alright, and turns at the head, and the tachometer doesn't work, then I would buy a new tacometer, (around $50.00), a new cable around($20.00). I wouldn't try and repair the old one, as you will spend more than a new one cost, my oponion of course. Good luck.....Van
Jim
03-02-2001 03:35:54
 Re: Re: 3000 hourmeter in reply to Van, 03-01-2001 11:58:06
I should have mentioned that the hourmeter doesn't work but the tach does.
Dan
03-01-2001 11:41:18
My cable from the tach to the generator was broken. It is an easy repair if that is it.
Bob Burke
03-01-2001 16:34:21
 Re: Re: 3000 hourmeter in reply to Dan, 03-01-2001 11:41:18
I had water getting into mine so I greased it up good and have not had a problem in years. Also take the gear out of the gen and lube it too.
