Order Ford 4000 Parts Online
4000 WFE on 950
Ed
04-09-2003 08:59:45
I want to convert my NFE 950 to WFE. I know that 900 series wide front ends will interchange. I have been searching salvage yards and have seen a 4000 wide front that looks it will fit on the 950. Can someone confirm that they are interchangeable, will any other model WFE fit?
Thanks
Geo in SD
04-09-2003 20:24:12
 Re: 4000 WFE on 950 in reply to Ed, 04-09-2003 08:59:45
Does your 950 have a one piece or two piece pedestal? A 4000 will have the two piece pedestal and spindle assembly. I believe it will replace the one piece assembly. The 4000 WF should replace anything built after 1957. Easy switch, 6 bolts.
Ed
04-10-2003 05:43:33
 Re: Re: 4000 WFE on 950 in reply to Geo in SD, 04-09-2003 20:24:12
I have a one piece pedestal. The switch to WFE would entail a change of the entire front mounting assembly. All 900 series front assemblies are the same -- not sure that the 4000 is the same. The 4000 front axle that I found only had the bottom half of the two peice pedestal so I could't compare the entire assembly.
Geo in SD
04-10-2003 10:37:33
 Re: Re: Re: 4000 WFE on 950 in reply to Ed, 04-10-2003 05:43:33
Just about positive the 4000 wf is the same. I just recently sold a 4000 wf to a guy who was going to do exactly what you are going to do with a 900.
