Starting problem
BDixon
04-09-2003 14:01:36
Hey everyone,
I am a newbie with my first tractor, a '63 2000. I am having a problem with the tractor not starting. It was converted to 12 volt before I bought it. It has a brand new battery and has only recently started not turning over. It does make a clicking sound when you try to start it. Any ideas would be appreciated. Thanks in advance.
Texas Tom
04-09-2003 19:22:44
 Re: Starting problem in reply to BDixon, 04-09-2003 14:01:36
You might want to charge your battery. Also, make sure your connections between the battery..solenoid..and starter are "clean..bright..and tight". However, my guess is your charging system is failing to recharge the battery....my 640 does the same thing..
Tommy
