Order Ford NAA Parts Online
1953 ford jubilee
ws
04-17-2003 04:03:57
how do you get the brakes off of a jubilee.thanks
raytasch
04-18-2003 14:57:08
 Re: 1953 ford jubilee in reply to ws, 04-17-2003 04:03:57
Loosen the axle nut; supposed to be torqued to 450 ft lbs. Leave the axle nut a couple turns loose and drive the Jub around over some rough ground till the hub comes loose. Then the hub will come off giving access to the brakes. Brakes same as an 8N.
ray
Phil (VA)
04-17-2003 11:57:59
Get a manual. Remove wheel, drum, brakes.
william
04-17-2003 17:58:23
 Re: Re: 1953 ford jubilee in reply to Phil (VA), 04-17-2003 11:57:59
i got the wheel off but can't get the drum off any suggestions
Phil (VA)
04-18-2003 06:39:28
 Re: Re: Re: 1953 ford jubilee in reply to william , 04-17-2003 17:58:23
Heat might work. Not too much. Maybe propane torch. Alternate heating, let cool, tapping with big hammer, etc.
