Question For Dell?
Al
04-17-2003 20:08:35
Dell, I have a 62 Ford 4000 with a 172 cu.in.gas engine.I found that the person who had it before me has the firing order backwards.# 4 is firing as # 1,# 3 is firing as # 2.so on and so forth.I talked to an old time tractor guy and he said he sees this quite often.My question is will this hurt anything.The tractor runs great and the timing is right on.Should i follow the old adage of "if it ain't broke don't fix it"Or should i set it right.
Ron,Ar
04-18-2003 19:41:58
 Re: Question For Dell? in reply to Al, 04-17-2003 20:08:35
You might re-post on the 8-n page, Dell is usually found there.
