Order Ford 4610 Parts Online
4610 PTO
BRIAN
04-22-2003 08:28:21
Does anyone know if the powertake-off shaft on the 4610 is a straight shaft or has a clutch pack? What would it take to change the shaft?Thanks.
DAVE M
04-22-2003 09:20:54
 Re: 4610 PTO in reply to BRIAN, 04-22-2003 08:28:21
It has a hydraulic clutch pack for engagement.
You will have to split the tractor.
What are your tractors symtoms?
If your pto spins while not engaged and still has
full power when engaged, it just might need the
pto brake tightned up.
DaveL
04-26-2005 20:56:19
 Re: Re: 4610 PTO in reply to DAVE M, 04-22-2003 09:20:54
I started out replacing the leaking PTO seal on my 4610 4wd. I removed the seal housing and could see that the bearing was packed with grass. I pulled on the shaft and it came out a few inches and stopped. It doesn"t want to go back in. Can anyone tell me if the bearing has to be pressed on with the shaft is removed and how do I get the shaft back in? Do I need to split the tractor or remove the top cover?
Don H
04-22-2003 12:54:29
I have a 74 4000 with the independent PTO. I can grab the PTO with my hand and stop it. It has full power. I thought I would have to replace the PTO brake. Is there an adjustment on it somewhere? Thanks
