Order Ford 3400 Parts Online
Ford 3400 industral Tractor
Al
04-22-2003 20:34:36
I have recently found a Ford 3400 industral series tractor. On a whim, I asked the guy if he wanted to sell it. To make a long story short, he is asking $1000.00 for it. He said it needs a new clutch. I haven't heard it run, but will before I buy! It has a decent looking front end loader on the front. Its a deisel engine. Has the protective cage over the operator. He has placed a bag over the steering wheel for keeping the water out of the transmission, and claims that was what happened to the transmission to begin with, water ran down the steering colume. It also needs the rear tires replaced and could use a paint job. I guess my question is, if this thing at least runs, what is it approx. worth??? I can't find anything on these on the internet. Thanks Al
Herb/pa
04-23-2003 05:43:39
 Re: Ford 3400 industral Tractor in reply to Al, 04-22-2003 20:34:36
It's worth 1000 in parts. I have a 1970 3400 gas I paid 5000 for about 3 yrs ago. It had surface rust but was running good. A clutch is not just a tinkering job. You have to split the tractor. The 3400 is an industrial 3000 series tractor with a heavier front end for loader work. If you intend to do loader work you might want power steering. Hope your seller doesn't read this discussion board! Reading this board, it seems you would not want a select-o-speed trans.
Al
04-23-2003 07:21:42
 Re: Re: Ford 3400 industral Tractor in reply to Herb/pa, 04-23-2003 05:43:39
you mentioned the select-o-speed trans, can you explain to me what that is?
Rick H. Ga.
04-23-2003 10:47:46
 Re: Re: Re: Ford 3400 industral Tractor in reply to Al, 04-23-2003 07:21:42
Al, from what I have read on this board it is basically an automatic transmission on a farm tractor. You just select a speed and go, hence, select-O-speed. I have also deducted from what I have read that it is wise to avoid them if possible. HTH. Rick H. Ga.
Rick H. Ga.
04-23-2003 05:08:32
Hi Al,
It sounds to me like you have stumbled on to a bargain. I would think it would be worth a $1000 if you are willing to invest more money in it and like to tinker. Rick H. Ga.
Al
04-23-2003 07:18:57
 Re: Re: Ford 3400 industral Tractor in reply to Rick H. Ga., 04-23-2003 05:08:32
I did forget to mention that it has power steering.
