Wiring question
6 volt Mike
04-26-2003 17:32:51
If I'm adding a rear light on a 6 volt system on my Ford 960, what is recommended.
I see the light I have is 30W at 6V, so I assume that I should plan on using 5 amps of current. Should I put an in line fuse for 7.5 amps, and what gauge wire?
I have a switch that says 12V for 20 amps, so that should ok.
thanks in advance
Scottey841
04-26-2003 18:51:21
 Re: wiring question in reply to 6 volt Mike, 04-26-2003 17:32:51
Your switch is OK. You can try the 7.5 amp fuse. If you blow the fuse sometimes you can go to a 10 amp fuse but no larger. 14 gauge wire will be fine and if the wire shorts to ground it can handle the current to blow the fuse.
