Order Ford NAA Parts Online
Front axle pivot on Golden Jubilee
B Seifert
03-03-2001 17:24:33
I have misplaced my IT manual (think I loaned it out). I noticed that the pivot on front axle squeaks when it pivots. Is there a way to lube this. At a glance I don't see any zerks to grease. Can anyone help me on this. Thanks Seif
Jeff(CT)
03-04-2001 21:26:41
 Re: Front axle pivot on Golden Jubilee in reply to B Seifert, 03-03-2001 17:24:33
Hey Bill, Maybe it's the field mice using the axle as a see-saw! Nope, No grease fittings. You might want to jack the front end up and check the threaded portion of the axle. That's where we found the problem with ours. I hope the threads on yours aren't as buggered up and worn out as ours was! You loaned out your manual!? I guess that's "history"! I did the same thing with 2 micrometer torque wrenches!!
Take care, Jeff
Duke
03-04-2001 14:19:40
There is no way to grease the front axle pivot. Apparently they thought that grease would hold dirt in there and wear out the bushing. You can try spraying some dry silicone lubricant in there to stop the squeek.
