Order Ford 4000 Parts Online
4000 Surging at high rpm with no load
joe smith
05-05-2003 12:36:50
63 4000 gas 172 selecto speed started a surging problem under heavier loads i.e. plow ing and disking replaced governor and fork, rebuilt carb many times, new tune up kit, spark plugs and wires new battery, new governor compensation assembly it now surges at no load (just sitting) at 2400 rpm it drops to 2200 rpm every second or so governor lever jumps forward half an inch or so
I disconnected governor rod and manually set throttle till i had 2400 rpm no surge or lever movement
could it be a smoothed over camshaft
please help need to work the hay fields at end of may
David (Ala)
05-06-2003 14:37:39
 Re: 4000 Surging at high rpm with no load in reply to joe smith, 05-05-2003 12:36:50
Have a 3000 that was doing the same thing. adjusted it out @ linkage between gov lever and carb throttle arm. See article below.
Click on tractors!
Al
05-05-2003 20:40:36
Sounds like it's the govenor or the adjustment.If it's not adjusted right it will surge.Start with the adjustment thats the easiest.
