195? Ford tractor.(selectospeed change)
Craig
05-05-2003 21:17:35
Looking at buying a Ford tractor with selecto-speed.Engine currently not running so I no way of noing how the transmission is?
What do I need to change it over to 4 or 5 speed besides the transmission , clutch, pressure plate,clutch pedal and arm.????
Also supposivly has no pto or 3 point,
Can this be added?
Should I maybe get a parts tractor or main parts needed only??? Thanks for your thoughts, Craig
Tom
05-06-2003 15:23:42
 Re: 195? Ford tractor.(selectospeed change) in reply to Craig, 05-05-2003 21:17:35
If they gave you the tractor, it would be too much. By the time you do engine, SOS transmission, 3 pt, PTO you will have more in it than it is worth.
Mike
05-06-2003 04:10:36
Graig,
If it were me, I would keep on looking unless you really need a tractor for pulling only, the 3 pt and PTO can be added, but usually it's more trouble than it would be to find another tractor already equipped. Good luck.
Mike
