Order Ford 3000 Parts Online
Ford 3000 oils
Alex
05-07-2003 17:32:25
can some one tell me what oils are used in my ford 3000 trans, diff, engine, and where the hydro pick up screen/filter is the 3000 is a 1969 gas thanks Alex
David (Alabama)
05-08-2003 20:55:35
 Re: ford 3000 oils in reply to Alex, 05-07-2003 17:32:25
Alex. Don't know about oils. But I had inspection plate off repairing pto shifter on my 3000 the other day. I believe I saw the hyd. filter through inspection plate opening. It would be on opposite side from plate. Didn't notice how it comes off, if it can be done through inspection opening or not. Go to link below then click on "Tractors" for some info about 3000. Pics showing some repairs coming soon.
David
Gary
05-18-2003 15:22:30
 Re: Re: ford 3000 oils in reply to David (Alabama), 05-08-2003 20:55:35
The oils used in the transmission only is 80w 90 gear lube..GL5 rating. The oil in the differential housing is Hydraulic transmissin oil. this where the hyd pump gets its oil from.
