Order Ford 901 Parts Online
901 Select-o-speed problem
birdatwork
05-10-2003 07:44:09
When I have the clutch in the tractor barely creeps along. Also even when I have it in neutral and the clutch out it does the same thing. I can usually switch gears some maybe to reverse and then back to neutral to get it to stop.
10th gear was out when I bought it. Now when I put it in 9th gear it goes for just a second the stops. Both of these problems have surfaced over just a couple hours of me using the tractor after I bought it.
Any suggestions on these problems? Do you think the whole transmission going out is imminent?
Larry NCKS
05-10-2003 10:03:42
 Re: 901 Select-o-speed problem in reply to birdatwork, 05-10-2003 07:44:09
1st symptom normal. 9th/10th might be torque clutch problem in flywheel. Does it pull any real load in the upper working gears?
