Order Ford 960 Parts Online
960 Lift Troubles... I Think
Bill-AZ
05-10-2003 20:32:56
I have been trying to do some ripping with the 960 but I am having a hard time. It seems as as tho the rippers just wont go into the ground, they just scuff the surface. I have changed the position and length of the top link but its just not working. When I put the rippers on the 2N it seems to get down in that dirt much better. But the 2N does not have any rear weight and looses traction to fast. Mind you this is some hard soil I am working, small horse pasture packed hard. But I have worked dirt just like this just a few weeks ago with the 960 and those rippers dug into the ground great.
I looked in the archives and found nothing on this except alot of talk about the cam follower pin...any chance? Please help, I am loosing money not getting these jobs done!
Thanks! Bill-AZ
paul
05-12-2003 05:07:38
 Re: 960 Lift Troubles... I Think in reply to Bill-AZ, 05-10-2003 20:32:56
If your 3point arms are going down, it shouldn't be the 3point problem. The cam follower is usually a problem with lifting things or smooth up motion. It would be odd that your 3point drops just to ground level, but no farther. Does it drop all the way down without the ripper on?
--->Paul
Bill-AZ
05-12-2003 21:17:04
 Re: Re: 960 Lift Troubles... I Think in reply to paul, 05-12-2003 05:07:38
Drops all the way down without rippers...I'm gettin frustrated. I bought a new top link a shorter one. I'll try that to see if a change in the angle is what its going to take.
