Order Ford 2600 Parts Online
2600
steve19438
05-11-2003 07:54:03
where is the ser. no. located on this model and how do i determine if it has live PTO or not?
many thanks
RickB.
05-11-2003 09:03:23
 Re: 2600 in reply to steve19438, 05-11-2003 07:54:03
It must be an 8 speed to have live PTO. But having 8 speeds does not guarantee live PTO. Take off in low gear with PTO engaged; push clutch pedal in till tractor stops. If PTO stops EXACTLY at the same time you do NOT have live PTO. IF you can stop tractor then push clutch further and stop PTO, you have live PTO working properly. If you can stop tractor and can't stop PTO with clutch pedal, you have live PTO that has problems. Live PTO tractors should have 2 holes in the clevis on front end of clutch rod. S/N is on data plate under hood and stamped on starter boss on clutch housing.
