12V Conversion for Selecto-speed need some instruction
Tom
05-11-2003 15:45:27
Good day, I am working on a 12V conversion for my 871 Selecto-speed.
The diagram is very straightforward but I need some assistance with this problem(s):
I have a Borg Warner 4 post soloniod
Push button with a wire to the Park or neutral safety switch under the tranny cover.
Key switch
and trying to get the tractor to start just in Park and not in all gears now that I have completed the wiring with this conversion.
Has anyone converted their 871/81 etc Selecto-speed and how did you do you it with a 4 post solonoid, push button starter button, and key switch? I can use your help.
Tom
Joe
05-12-2003 04:58:30
 Re: 12V Conversion for Selecto-speed need some instruction in reply to Tom, 05-11-2003 15:45:27
You have to use an isolated ground solenoid. Not all 4 post solenoids are isolated ground. The wire. The diesels used a 12v system. wiring is the same as the 6v.
Tom
05-12-2003 07:04:55
 Re: Re: 12V Conversion for Selecto-speed need some instruction in reply to Joe, 05-12-2003 04:58:30
Thanks. Worked it out.
From the push button terminal one wire to tranny cover/park safety switch. Other push button terminal wire goes to one small post on the solonoid.
On the other small post on the solonoid a wire goes to the key switch contact so when the key is turned on it energizes the solonoid and then sends current to the push button.
