Help! Bushhogged last nite, now PTO won't engage(2 stage clutch)
back40
05-21-2003 04:19:39
I was bush hogging last night with my 960 (2 stage clutch)and I disengaged the PTO to travel back to the house. When I got close to the house I wanted to mow a little bit more but the PTO lever couldn't be moved into position to engage the mower. No matter how many times I tried, I couldn't get the PTO engaged. The clutch pedel seems normal, but the lever just won't go. What could be the problem?????
Phil (VA)
05-23-2003 07:36:07
 Re: Help! Bushhogged last nite, now PTO won't enga in reply to back40, 05-21-2003 04:19:39
If you haven't done so, unhook the mower from the PTO, to make sure it isn't in a bind of some sort with the mower. That may not help, but you are going to have to do that anyway, so it's something to try.
Don C
05-22-2003 04:45:33
 Re: Help! Bushhogged last nite, now PTO won't engage(2 stage clutch) in reply to back40, 05-21-2003 04:19:39
When you say it won't go in, does it grind when you try to engage it or will the lever just not move at all?
back40
05-22-2003 05:10:35
 Re: Re: Help! Bushhogged last nite, now PTO won't engage(2 stage clutch) in reply to Don C, 05-22-2003 04:45:33
The lever just won't move. It doesn't grind at all. Any suggestions????? ??
rayinpa
05-23-2003 08:20:15
 Re: Re: Re: Help! Bushhogged last nite, now PTO wo in reply to back40, 05-22-2003 05:10:35
I had similar trouble with my 860 last year. turned out the pto shaft had twisted when I hit a rock. the pin didnt shear like its supposed to for whatever reason. this year a similar difficulty ended up being that the clutch was out of adjustment. did you hit anything when you were mowing or run over a mound of dirt that may have bogged down the tractor but not stalled it or shear the pin? if not try clutch adjustment.
good luck
Ray
back40
05-23-2003 08:43:26
 Re: Re: Re: Re: Help! Bushhogged last nite, now PT in reply to rayinpa, 05-23-2003 08:20:15
Yes, I did run over a mound of dirt that bogged the tractor down a little. I unhooked the mower's PTO shaft and can easily spin the tractor's PTO shaft. If the tractor's PTO shaft had twisted, would I still be able to spin it easily?
rayinpa
05-26-2003 13:09:29
 Re: Re: Re: Re: Re: Help! Bushhogged last nite, no in reply to back40, 05-23-2003 08:43:26
honestly back40 I don't know for sure. I think it may still be able to spin easily.Ray
