172 cu.in.
Al
05-25-2003 21:03:25
I have a later model Ford 172 cu.in. gas engine (3.90" pistons )that is sleeveless.My question is can it be bored to accept sleeves.
Gary-Miss
05-26-2003 20:55:16
 Re: 172 cu.in. in reply to Al, 05-25-2003 21:03:25
Yes-you can sleeve it. Normally, one does not, except for several reasons. If it is worn past the point where you can bore it and find pistons is one reason. Then, you bore the sleeves back to standard. This gets a little expensive because it's a lot of work. I have bored a 3000 diesel due to cavitation pinhole in the lower cylinder about 5-6 years ago. We bored it on the trailer with a boring bar that clamped in the bottom of #2 cylinder. The man now uses anti-cavitation additive.
