Order Ford 3000 Parts Online
Ford 3000 clutch release arm
Bob Washington
05-26-2003 16:23:16
Cracked the clutch release arm and am trying to figure how to get just the arm off the shaft for repair or replacement. No sign of a pin or set screw. Any ideas?
Richard C. Rose
05-28-2003 02:33:18
 Re: ford 3000 clutch release arm in reply to Bob Washington, 05-26-2003 16:23:16
Hi Bob
I believe if you are looking at the 'release arm' outside the bell housing it is welded onto the shaft. You need to split the tractor to remove it.
If it is the release fork you are looking at,you are already inside the bell housing and it is bolted onto the shaft, you only need to tip the fork forward to see the bolts.
Good luck
Richard
