Order Ford 4000 Parts Online
4000 CLUTCH
K R HART
06-12-2003 10:06:15
What could be wrong with my 67 4000 clutch that would cause it to not disengage when pedal is pushed. Have already adjusted linkage on pedal about as much as possible. All help greatly appreciated. KRHART
RWK in WI
06-12-2003 19:01:15
 Re: 4000 CLUTCH in reply to K R HART, 06-12-2003 10:06:15
I could be that you have a "frozen or stuck clutch". Due to moisture the clutch facing stickes/ rusts to the plate. It can be avoided by blocking the clutch pedal is the down position when parked.
I some cases driving the tractor in gear, holding the clutch down, and hitting the brakes hard will pull it loose. In my case it took about 20 minutes of driving up and down the back road hills to pull it loose.
Hope this help you. Dick Kraus
Lee
06-12-2003 11:38:37
Sounds like you need to replace or have replaced one clutch assembly.
Mark K.
06-12-2003 22:42:03
 Re: Re: 4000 CLUTCH in reply to Lee, 06-12-2003 11:38:37
Hello,
On mine I knew that the clutch was getting weak and slipping and was expecting it just to not move someday. I found it wouldnt disengauge, after spliting I found that the pressure plate fingers were wore out. The throw out bearing had locked ( I didn't hear it ) or something. Replaced it all but I went to a clutch reman. place insted of ordering it from FNH and the springs are too stiff. My left leg is larger than my right now.
Mark
