Order Ford 841 Parts Online
841 Power Steering Leak
Alan
06-15-2003 14:31:05
Hi....Mowing today and my 1960 841 power steering fluid started to leak like crazy from the sector box pedestal. Assume this is a bad seal somewhere....Is this a fairly easy repair for an amateur mechanic....or is this best left for a professional...I have the IT manual, and the steering box looks like it has lots of parts...scared to start tearing it down.
thanks
George H
06-15-2003 16:26:21
 Re: 841 Power Steering Leak in reply to Alan, 06-15-2003 14:31:05
The only power steering leak I've had to fix was from a cracked hose fitting at the control valve, about in the middle of the steering box. Sheet metal was off and gearbox was cleaned, so it was easy to run the engine and spot the leak. You'll just have to peer under there. I believe all the steel lines/hoses can be replaced by removing the battery/batterybox/air cleaner, but maybe also the vertical dash metal.
